 Needing replacement piece of pillar panel
wagnluvr
Needing replacement piece of pillar panel  Empty
PostSubject: Needing replacement piece of pillar panel    Needing replacement piece of pillar panel  Icon_minitimeFri Oct 20, 2017 12:34 pm
Anyone know where I can order a new cover panel for outside passenger door pillar? This is for my 91 Olds Custom Cruiser and is the piece just to the left of the window.
PostSubject: Re: Needing replacement piece of pillar panel    Needing replacement piece of pillar panel  Icon_minitimeFri Oct 20, 2017 2:18 pm
Those are also called the "fly away" panels. You can use the same ones from a Roadmaster Wagon too. It's the same pieces that your 91 OCC has.
I know someone on here has some. I tried to message you too...but did you buy a Factory Service Manual yet? I have one I will gladly give you. Just message me back on FB.
PostSubject: Re: Needing replacement piece of pillar panel    Needing replacement piece of pillar panel  Icon_minitimeFri Oct 20, 2017 4:38 pm
I have one in White, just don't recall which side it is right now. I'll check and update
» Needing help with replacement radiator.
» Questions on C pillar removal/replacement
» needing pics of systems
» Possible reason for D pillar rust
» Hitch Hardware Need to Find.
