 Moog Problem Solver Ball Joint
Haze5736
Moog Problem Solver Ball Joint Empty
PostSubject: Moog Problem Solver Ball Joint   Moog Problem Solver Ball Joint Icon_minitimeSat Aug 18, 2018 4:45 pm
I just replaced the left lower ball joint on my 96. I used a Moog Problem Solver. It came with a separate grease boot, not attached. So I pressed the ball joint in and am trying to figure out how the grease boot is supposed to be installed. I can't seem to press it on evenly and get it to stay seated. Do I just place it on top and let the weight of the knuckle hold it down? I tried adding a little grease but it is starting to come out at the lip that is not seated. Does anyone know how this is supposed to be installed?
PostSubject: Re: Moog Problem Solver Ball Joint   Moog Problem Solver Ball Joint Icon_minitimeSat Aug 18, 2018 7:45 pm
The weight will help hold it in place, but it should seat around the flange. Check to see that you pressed the balljoint all the way in. Using a piece of pipe that just fits over the boot may help get it seated.
Haze5736
PostSubject: Re: Moog Problem Solver Ball Joint   Moog Problem Solver Ball Joint Icon_minitimeSun Aug 19, 2018 7:10 pm
I ended up having to use one of the ball joint press receivers and hit it with my 3lb hammer to seat it. I first tried channel locks by seating the inboard side first then using the channel locks on the outer side and grabbing under the control arm. I did not have any success with that method.
» Lower Ball Joint?
» upper ball joint?
» GM lower ball joint tool
» Upper ball joint bolt issue?
» Moog 5030's
