 Turn signal fuse pops when put into reverse...
Boomhauers_93Wagon
Turn signal fuse pops when put into reverse... Empty
PostSubject: Turn signal fuse pops when put into reverse...   Turn signal fuse pops when put into reverse... Icon_minitimeSun Jun 07, 2020 7:18 pm
My 96' DCM RMW wagon is been problematic as of late.
But I just finished replacing my turn signal switch, all was well with the world.
I now find that when I put it into reverse the turn signal fuse pops...
Everything looked good wiring wise on the column when I was doing the switch...
I don't know where to go from here.
» Turn Signal Flasher
» Turn signal stalk removal.
» turn signal
» Turn Signal Conked Out
» turn signal issue
