Posts : 69 Join date : 2017-09-13 Location : Victor,NY,14564
Subject: Rear sway bars- are they too low? Tue Nov 21, 2023 8:42 am
I was looking at some RMW with rear sway bars at Wagonfest
They look low.
Do they end up striking things From time to time?
I have 17 inch Impala Rims and stock springs so I am not lowered.
Subject: Re: Rear sway bars- are they too low? Tue Nov 21, 2023 1:58 pm
The anti roll bars do not hit on Impalas, so they should not hit on wagons. The Impala springs are shorter than wagon springs as well.
rcktpwrd
Subject: Re: Rear sway bars- are they too low? Tue Nov 21, 2023 7:43 pm
rear sway bars on this style GM rear suspension usually look like they hang low, but there are other things towards the front of the car just as low or lower. I think if you were to hit something with the rear bar you would have already hit things up front.
sherlock9c1 likes this post
Subject: Re: Rear sway bars- are they too low? Sun Dec 24, 2023 7:03 pm
Whatever clearance you have at the rollbar Is the same no matter what springs you have. The clearance is determined by the tire diameter.
GeoffB likes this post
dmg4 Moderator
Subject: Re: Rear sway bars- are they too low? Wed Dec 27, 2023 6:27 am
Quote :
Not on my '96 Caprice wagon. I used the rear bar from Hotchkis and Southside Machine Lower control arms (just for the no-drill or welding/fab convenience). You'll beat the bejeezus out of the differential housing before the swaybar hits anything.
