bigbluey88
Posts : 252 Join date : 2013-06-16 Age : 37 Location : windsor locks CT
| Subject: water leaking when rains Tue Jul 23, 2013 9:47 am | |
| Water leaking in drops when it rains from drivers side above the window before the windshield on the left checked and felt around have no clue why or how to fix it | |
| Subject: Re: water leaking when rains Tue Jul 23, 2013 9:57 am | |
| have you got a carport or a garage? | |
bigbluey88
| Subject: Re: water leaking when rains Tue Jul 23, 2013 10:08 am | |
| I do I usually put the caprice wagon(silver beast) in there but I was on my way home from work when I noticed it dripping on the side | |
Posts : 3371 Join date : 2008-11-05 Age : 75 Location : Littleton, NH & St. Simons, GA
| Subject: Re: water leaking when rains Tue Jul 23, 2013 10:53 am | |
| Check the door gasket between the body and door. On my 94's the gasket has a fold which can trap pine needles etc. Make sure it is clean so water can drain. If it is plugged up, water will drip inside. Had that exact problem. Glass man pointed that out to me.
Also check the fold in the gasket that is on the side of the windshield.
bigbluey88
| Subject: Re: water leaking when rains Tue Jul 23, 2013 11:13 am | |
| Thanks will definitely check that out | |
68scott385
Posts : 25 Join date : 2013-06-13 Location : Louisville, KY
| Subject: Re: water leaking when rains Tue Jul 23, 2013 11:25 pm | |
| LM18LBC front LM18LW rear
These are part numbers for the door weatherstrip from RockAuto, if you need them. | |
| Subject: Re: water leaking when rains Fri Aug 02, 2013 10:51 pm | |
| My 91 started to have spot of rust and a leak along the top of the windshield. I only found it because I broke the front windshield and had to have it replaced. | |
| Subject: Re: water leaking when rains | |
