 Oil leak at the distributor?
TylerW
Oil leak at the distributor? Empty
PostSubject: Oil leak at the distributor?   Oil leak at the distributor? Icon_minitimeWed Jan 27, 2010 4:31 pm
Hey guys:
I've put about 4500 miles on my '91 RMW so far, and it's been leaving small puddles of oil everywhere.
It was time to do an oil change today, so I took the opportunity to track down the leak.
It appears it is leaking out around the base of the distributor, but I'm not 100 percent sure until I can get further in there and clean it off.
I found what appears to be a ring of form-a-gasket just hanging around the distributor base, and in fact the dist was loose when I got this car, causing it to hardly run.
What is supposed to be in place to seal off oil leaks? Is there an o-ring on the distributor, o-ring plus a seal on the block, or neither lol...
Thanks for the help....
WagonLover
WagonLover
PostSubject: Re: Oil leak at the distributor?   Oil leak at the distributor? Icon_minitimeWed Jan 27, 2010 4:50 pm
i kno on my 92 RMW there is a gasket inbetween the distributor to the intake..
https://www.photobucket.com/wagonlover
PostSubject: Re: Oil leak at the distributor?   Oil leak at the distributor? Icon_minitimeWed Jan 27, 2010 5:36 pm
Odds are the Intake mANIFOLD is leaking because it is a very common SBC problem. Just pull the intake and reseal everything. The Felpro gasket set will include the gasket for the distributor base.
» Distributor bad?
» distributor?
» Will this distributor fit?
» Distributor noise
» O-Rings on distributor drive shaft
