| | 2-3 gear late shift, no 4th gear | |
| | Author | Message |
PSchelly
Posts : 17 Join date : 2013-06-02 Location : Bettendorf, IA
| Subject: 2-3 gear late shift, no 4th gear Fri Aug 30, 2013 9:45 pm | |
| Dear fellow longroof fanatics,
The transmission on my '95 rmw with 180,000 miles on it (that I've owned since June) just started acting up. It shifts from 1st to 2nd fine, but then takes forEVER to shift to 3rd - I have resorted to damn near gunning it in 2nd, then letting off the accelerator, at which point it'll shift into 3rd. And I have no 4th gear at all that I can tell. This all started happening last Friday, out of the blue. She was running like a top up until then.
I took it in to & got the transmission fluid sucked out & replaced (I know, I know - some people will tell me that's insane, that it will only bring more issues, but that wasn't the case). The fluid they sucked out was black as coal - and there was only 2 quarts in there ! It is now all fresh & pink(ish)... but the problem persists.
I've done as much homework on this site (I enjoy the HELL out of this site, btw), and I've narrowed it down to the following possible issues:
* Shift solenoids 3-4 * PCM (Is this like an ECM ?) * Chip (?) * Shifter position sensor * Modulator valve * "TV cable" adjustment (?) * 3-4 clutches * 3-4 clutch bands * Governor * Torque converter
I have a good amount of mechanical aptitude, but have never worked on a tranny, so.... As you can see by this list, I'm not really sure what most of these things are, as I'm certain I have repeated the same part, only with a different spelling.
What are your thoughts ? Do any of these 'issues' jump out at you as the culprit ?
Am I looking at a transmission rebuild ? (I hope not ! - however if I am, I'd like to put in a manual transmission >:-P)
PLEASE HELP !
Ty in advance - Skook | |
| | | bamalongroof
| Subject: Re: 2-3 gear late shift, no 4th gear Fri Aug 30, 2013 10:02 pm | |
| I'm not a trans guy but last night I watched the 4L60E rebuild on youtube and learned a lot. ECM and PCM refer to the same unit "Power Control Module" and "Electronic Control Module" the computer for you engine and trans you should be able to find one at a Pick a Part to swap out and check your current module. Jeff (my wagon is new to me also) | |
| | | PSchelly
| Subject: Re: 2-3 gear late shift, no 4th gear Fri Sep 06, 2013 11:18 pm | |
| I did some research on swapping out the ECM, and it seems that you need to have it programmed to your VIN number - is this true ? | |
| | | sherlock9c1
| Subject: Re: 2-3 gear late shift, no 4th gear Fri Sep 06, 2013 11:42 pm | |
| The trans is worn out. Black fluid is a dead giveaway, and the soft-delayed shift points directly to a worn out 3-4 clutchpack. Time for a rebuild.
You could try to replace just the 3-4 clutchpack but I guarrantee you that, with that mileage, there are 4-5 other things right in line to fail right after this one.
BTW the following are non-existent in '94-96 cars: * Chip (?) * "TV cable" adjustment (?) * 3-4 clutch bands * Governor | |
| | | PSchelly
| Subject: Re: 2-3 gear late shift, no 4th gear Sat Sep 07, 2013 12:13 am | |
| Sherlock9c1,
Although I was hoping for something other than that answer, Thank You for your input.
What are your thoughts about dropping a manual transmission in her ? | |
| | | sherlock9c1
| Subject: Re: 2-3 gear late shift, no 4th gear Sat Sep 07, 2013 12:20 am | |
| If you like manual transmissions, save up $3k and do it. If you (like me) don't, don't bother. I continue to amaze myself that every time I drive one of these cars converted to a 6-speed, I like automatics better. | |
| | | Sprocket
| Subject: Re: 2-3 gear late shift, no 4th gear Sat Sep 07, 2013 8:49 am | |
| If you like rowing gears, it's a great swap. I've driven one and am in the process of amassing parts, it totally changes the character of the car (for the better in my opinion). As Joel mentioned, it'll be a few $$. The swap to a wagon or sedan si the same and it's been done quite a lot, Lots of info on ISSF about it.
If you are lucky you can find a total swap that some else is done with for about $2K. If you see that jump on it.
Big ticket items:
Lt1 t56 and bell housing - 800 - 1400 depending on condition and how anxious to sell Trans cross member - 250 or so from Clear image F2B kit - for putting the extra pedal in the car ~450 (pedals not included) Rear end gears - couple to several hundred PCM tune - gotta reprogram the compute ~150
And lots of other little stuff. As you can see you already at 2k or better. This why my budget build is so slow going as I'm buying as I have spare cash and/or the screaming deal floats by...
| | | Sponsored content
| Subject: Re: 2-3 gear late shift, no 4th gear | |
Similar topics | |
