 Custom Cruiser Door Lock Module
vettfingers
Custom Cruiser Door Lock Module Empty
PostSubject: Custom Cruiser Door Lock Module   Custom Cruiser Door Lock Module Icon_minitimeTue Nov 19, 2013 10:03 pm
Looking for a working power door lock module. According to GM only fits Custom Cruiser 91-92. Thanks!
PostSubject: Re: Custom Cruiser Door Lock Module   Custom Cruiser Door Lock Module Icon_minitimeWed Nov 20, 2013 8:12 am
Are you talking about this relay? RockAuto.com has them starting at $19 for aftermarket up to $43 for AC Delco brand. Also, I believe this is shared with the Caprice if not the Roadmaster as well.
Custom Cruiser Door Lock Module Getimage.php?imageurl=http%3A%2F%2Fwww.rockauto.com%2Finfo%2FSMP%2FRY110_PRIMARY
vettfingers
PostSubject: Re: Custom Cruiser Door Lock Module   Custom Cruiser Door Lock Module Icon_minitimeWed Nov 20, 2013 4:58 pm
No, i may have lead you in the wrong direction. this is for the keyless entry system. The module is located in the rear behind the lh trim panel over the wheel. gm part number was 22586688. it has 2 plugs going to it, both having about 8 wires. Thanks.
PostSubject: Re: Custom Cruiser Door Lock Module   Custom Cruiser Door Lock Module Icon_minitimeThu Nov 21, 2013 8:28 pm
roadmaster should work too.  local JY run!!
alot of parts at auto stores are not listed for OCCs just use same year roadmaster estate they are the same aside from cosmetic differences
PostSubject: Re: Custom Cruiser Door Lock Module   Custom Cruiser Door Lock Module Icon_minitimeThu Nov 21, 2013 11:09 pm
I believe the wagon and sedan units are the same. They have the same numbers on them. I have one for $32 shipped. The way you tell the 91-93 from the 94-95 is that the later model ones have green connectors.
» Oldsmobile Custom Cruiser Door Chime
» Remote lock drivers door lock problems
» 1992 Oldsmobile Custom Cruiser Oldsmobile Custom Cruiser Wagon - $9,995 (Lenoir City)
» Door Lock Switch for Driver door
» Door lock programing ?
