 Rear cargo light on while engine running
Rear cargo light on while engine running Empty
PostSubject: Rear cargo light on while engine running   Rear cargo light on while engine running Icon_minitimeMon Nov 25, 2013 9:51 am
Ok, so on the 'new' 92 wagon that my son took. Whe the engine is running the rear driver's side cargo light goes on about half brightness (like there is a dimmer on it) so I know it's not getting full voltage. Also the Gate Ajar light is on all the time and yes, I checked the gate is closed both ways.
Also the Load leveler runs for about 3-4 min after you kill the engine (assume leaky shocks as they are SOFT).
Any ideas on the first two?
YachtDriver
YachtDriver
PostSubject: Re: Rear cargo light on while engine running   Rear cargo light on while engine running Icon_minitimeMon Nov 25, 2013 10:21 am
The gate ajar and light being on sound like a ground issue in the door circuit. Or a wire is chafed and grounding out somewhere. Ground = on with the door circuit.
Remove the light delay relay in the drivers kick fuse panel and see if the gate ajar light and the dim light go out. In a 96 it's right next to the horn relay.
If this works then you know it's related to the circuit for the door lights. It should be a good workaround until you find the issue.
Have the same problem in the MAB Roadmaster. I have yet to find the bad ground and with the relay removed it will at least not be on at night when you are driving. You just won't have the interior lights when you open the door.
Again this is for a 96 but it may work on a 92. I don't know the differences in the wiring.
» rear cargo light mod
» wtb: rear cargo area light covers
» Rear cargo area - light lenses
» engine compartment light?
» horns wont sound unless engine running
