 weight distributing hitch, and trailer brake controller
zach.skinner510
weight distributing hitch, and trailer brake controller Empty
PostSubject: weight distributing hitch, and trailer brake controller   weight distributing hitch, and trailer brake controller Icon_minitimeWed Oct 30, 2013 5:09 pm
now that i found a suitable reciever hitch looking for a weight distributing hitch and brake controller. Im lost there are so many types and options. what should i look for, and do the make a plug in harness for our cars or will i have to hardwire it in? any help is appreciated
zach.skinner510
PostSubject: Re: weight distributing hitch, and trailer brake controller   weight distributing hitch, and trailer brake controller Icon_minitimeThu Oct 31, 2013 4:58 pm
No suggestions?
PostSubject: Re: weight distributing hitch, and trailer brake controller   weight distributing hitch, and trailer brake controller Icon_minitimeThu Oct 31, 2013 5:24 pm
Zach:
I have been using a WD hitch called the "Equalizer" now for over 5 years. Best conventional one I have ever used. All the rest are only imitators. Does combine both WD and sway control in one.
If you have very deep pockets, by far the best is a thing called a "Hensley". Works on a totally different design but will set you back a couple of grand. Granted its the last one you'll ever have to buy but expensive none the less. Have driven a couple of rigs with a Hensley and the difference is remarkable. Absolutely no sway whatsoever, not even buffeting. Trailer and TV rock solid in all conditions.
Spend the money on an Tekonsha Prodigy P3 controller. Best of the bunch. don't waste your money on the cheaper controller as you'll eventually end up with the Prodigy anyways. The direct plug in wiring harness is still available for our cars.
http://www.etrailer.com/Custom-Fit-Vehicle-Wiring/Buick/Roadmaster/1994/C55347.html?vehicleid=19941170402
This is only for the lights and you still have to convert the flat plug to a 7 way and wire in the controller separately (our cars never had factory trailer wiring).
Hope this helps
zach.skinner510
PostSubject: Re: weight distributing hitch, and trailer brake controller   weight distributing hitch, and trailer brake controller Icon_minitimeThu Oct 31, 2013 6:15 pm
How much tongue weight do I want? If I understand correctly you can buy different bars to change the tongue weight? Correct me if I'm wrong here, I've always just threw a trailer behind a pick up and never thought twice.
COL
COL
PostSubject: Re: weight distributing hitch, and trailer brake controller   weight distributing hitch, and trailer brake controller Icon_minitimeThu Oct 31, 2013 8:00 pm
Zach,
The rule of thumb is 10% of the trailer weight for the hitch weight. There are two factors. One is sway control and the other is distribution of the weight. Without a WD hitch, the weight on the rear of your tow vehicle raises in the front, making the steering light. The WD system makes the tow vehicle and trailer operate as one unit. From what I have researched, Bill is right. Hensley is the best. I do not have one. I cannot afford a Ferrari either.
I haul a 1958 Airstream (22') with my OCC. I have been very happy with an Equal-I-zer brand system. Take a look at this site for a good explanation on how it works.
http://www.equalizerhitch.com/
Dick
zach.skinner510
PostSubject: Re: weight distributing hitch, and trailer brake controller   weight distributing hitch, and trailer brake controller Icon_minitimeThu Oct 31, 2013 10:33 pm
Thanks for the link sounds like what I need. My budget it is small at best 5 kids and the wife stays at home. So gotta shop around and get best deals, and do a little at a time but hey that's life
PostSubject: Re: weight distributing hitch, and trailer brake controller   weight distributing hitch, and trailer brake controller Icon_minitimeThu Oct 31, 2013 10:51 pm
I have used a Reese trunnion style for the last 25 years or so, and it's never let me down (sorry, couldn't resist the pun). I don't remember the model name, but it was their top-of-the-line model in it's day, with a fully adjustable (height, angle) head. I prefer the trunnion style over the round bar style for the improved ground clearance.
Also, Reese has their "dual cam" sway control accessory, which is (IMHO) superior to a friction sway control, but additional sway control is probably overkill for a 20' tandem house trailer -- at least, behind one of these wagons.
Whatever system you choose, pick a set of bars with the appropriate rating. Bars are nothing more than springs; bars rated substantially higher than the tongue weight won't have any give, and lead to somewhat erratic handling. Bars rated less than the tongue weight will be too soft, and won't be able to transfer the weight properly. For example, let's say your trailer (LOADED!) is 4,500 lbs and you have a choice of 350, 550 and 750 LB bars in your preferred brand. Pick the 550 bars. 350 bars will be too soft, and 750 bars will be too stiff.
I will defer to others about the current offerings in brake controllers (sorry again Very Happy ). As with any electronic technology, I'm sure the field is in a constant state of flux (oops, it just slipped out, honest).
Ok, seriously, I will say I vastly prefer a proportional brake controller over a timed brake controller, but to be honest, it's been so long since I bought one that I have no idea if the timed ones are still out there. And I vastly prefer one that uses a pendulum rather than ties into the vehicle's hydraulic system. I kind of doubt the latter would play nice with ABS anyway.
I also feel a manual control (again, proportional) is a worthwhile safety feature. There are times when you might need to apply the trailer brakes independently. All proportional controllers should have an adjustment to fine-tune the ratio of the trailer brake force to the vehicle brake force. Pendulum types should have an angle adjustment to zero out the pendulum, compensating for the mounting angle of the controller.
One important consideration is the current handling capacity of the controller. A tandem axle trailer will have twice as many brakes as a single axle trailer, and potentially draw twice as much current. If you have the owner's manual for the trailer, it should tell you how many amps the brakes can draw. If not, you can measure it with an ammeter by applying full voltage (with the car running) to the brakes. If all else fails, the rule of thumb used to be 6 amps per axle.
There's no problem using a controller rated 18 amps on a single axle trailer, but trying to use one rated 6 amps on a tandem will result in reduced braking power and can even burn out the controller. Make sure the wiring between the controller and the trailer is adequately sized too. We don't want another car fire thread...
» Electric Trailer Brake Controller
» Wanted: '95 Caprice Classic Station Wagon owner's manual and a class III/ IV trailer hitch with 2" hitch receiver
» weight distribution hitch
» Brake controller wiring
» U-haul Trailer hitch
